To predrill or Not to predrill
Username: Lewass
Bloomfield Hills, MI USA
Post Number: 258
I'm just about done with my box for 3 10's, I am wondering if I should predrill the holes before I screw in the subwoofers themselves????
In the past I have not predrilled but just drilled in, what should I do??
Username: B101
Queen City, NC USA
Post Number: 1853
dont predrill, just drill when u get subs... its not hard at all man!
Username: Lewass
Post Number: 259
I have the subs I'm ready to put them in, should I predrill or just screw them in?
Username: B101
Queen City, NC USA
Post Number: 1854
just screw them in with the subs...
Username: B101
Queen City, NC USA
Post Number: 1855
just be carefull not to drill your subs...
Username: Yukhui
Myrtle Beach, South Carolina USA
Post Number: 266
I decided to predrill before...Now i have 16 holes per hole lol.
Username: Yukhui
Post Number: 267
I decided to predrill before...Now i have 16 holes per sub hole lol.
Username: Lewass
Post Number: 260
Haha, yea I just drilled them in and it seems ok. It turned out amazing, I can't believe how great they sound, probably the best sounding subs i've ever heard, and it's my first box!
Username: Winterfreshpimp
Chisago, MN America
Post Number: 63
what kinda subs... just out of curiosity
Username: Chaunb3400
Huntsville, Alabama U.S.
Post Number: 6132
are those the SPL=JL, 10's ur where talking about???
Username: Alteraudiousa
Concord
Post Number: 466
predrill all the time. If you don't you can get it where the wood gathers on the edges and pushes back up. I like to predrill with a very small bit and then screw in.
Username: Rovin
Trinidad & T...
Post Number: 6681
Agreed ^^^^! - makes life alot easier .....
Username: Lewass
Post Number: 261
Yea chauncey they are, and they hit so crisp and beautiful, and they are only excurting half way!! I don't have enough power to push them all the way, my next buy will have to be a new amp, maybe a JL 1000/1 and run them at a 4 ohm load..
Username: Rovin
Trinidad & T...
Post Number: 6682
Username: Young_james
Post Number: 986
^^^x2
Username: Solacedagony
New Jersey US
Post Number: 825
Predrilling is required with MDF or it will just disintegrate.
Username: Lewass
Post Number: 267
HAHA, no way that just got busted out on me!!! I was gonna post all the pics anyways, but I gotta bluetooth them from my phone, which I will do later.
Oh yea, IT WONT FIT IN MY TRUNK!!! by like half an inch!!! hahaa
So I put it in my back seat :-)
Username: Matt12490
Benicia, California USA
Post Number: 436
have you tried taking out your back seat and putting them in from the inside of the car?
Username: Lewass
Post Number: 268
No but I was thinking about that, I will be getting a new car soon though so I don't know how worth it it is..
