Witch sub's will be louder ??
Username: Night_mirage
AmmanJordan
Post Number: 182
with sx1250.1 amplifier
witch will be louder .
1/ two 10" CVX kicker
2/ two 10L7 kicker
3/ one 10W6 JL audio
4/ two 15" CVR kicker
5/ three 12" CVR kicker
6/ two 12" W3 jl audio
in Ported Box
Username: Jmloughrey
Farmington, CT
Post Number: 1447
no real way to tell...depends alot on the box, power, install, and the car/suv...
AmmanJordan
Post Number: 185
the car is mercedes_Benz E-class 1999 .
what is your opinion .
Username: Ucfsaxman
Oviedo/orlando, Fl
Post Number: 694
probably the 3 12 CVR's I'm not sure about those new CVX since i have never heard them so I don't really know what they're capable of I have heard the 10 L7 and they are not that loud I think it would be easiest for the 3 12's to get the loudest. the others may get as loud but would require some extensive box building. the Jl would not work w/ that amp it would be too powerful for either of those choices.
AmmanJordan
Post Number: 188
tHANKS
ucfsaxman
I am thinking now about three 12" CVR or two 10 CVX in ported box .
what do you think about two 15" CVR .
Username: Alteraudiousa
Concord
Post Number: 463
IMO, the two 15s may the louder, alot will depend on the box and the subs specs which I haven't look at. What kinda of power are you looking to have on tap. A 3 sub setup gives some odd ohm loads like 2.67 or 1.33 while the two subs can give a 2 or 1ohm load. If the two 15s are getting more power it may be just as loud or slightly louder.
Username: Rovin
Trinidad & T...
Post Number: 6647
"A 3 sub setup gives some odd ohm loads like 2.67 or 1.33"
i agree with that ^^^ - i keep telling ppl here that it complicates matters trying 2 get an amp 2 do the job right .
If were me i'd get 2 RE SE 15s www.reaudio.com ......
Username: Safe_cracker
Chicago, IL US
Post Number: 491
He won't have enough room in that car for 2 RE 15s in a ported box. I have two sx's that I coud not fit in my Grand prix and I have a good sized trunk. Remember they recommend 3.5 cf per sub ported and that is on the minimum. I have found they sound best with 4.47 cf so maybe a single 15sx with that amp will pound nicely. JMHO...Polo. :-)
AmmanJordan
Post Number: 190
okay thanks alteraudiousa
but if i want to buy three 12" of cvr >> is that work with that amp >
or on this ohms will be so bad >
Username: Rovin
Trinidad & T...
Post Number: 6652
Um ok - cause i'm not familiar with the trunk of that car
but then will 3 12s fit ? - 2 should though ....
AmmanJordan
Post Number: 191
okay guys what do you think i can put two 15" in ported box in my car room > what is the box size would i biuld for pair 15" .
lets say we 've now >
two 15" CVR .
two 10" CVX
three 12" CVR
what do you think ??
AmmanJordan
Post Number: 192
the car room is about 100cm lenght 50cm high >>
AmmanJordan
Post Number: 193
guys can i install pair of 15" CVR in my mrecedes trunk .
50cm for lenght
100cm for widht
50 for high
Username: Lewass
Bloomfield Hills, MI USA
Post Number: 264
3 subs is weird ohm loads yes, but not if they are 3 DVC 6 ohm VC's like mine hehe. Mine have the perfect wiring options. I can go 1 ohm load, or 4 ohm load :-)
AmmanJordan
Post Number: 198
okay with sx1250.1 what should i have buy three cvr 12"
4 or 2 ohm
