Slot or round port????
Username: Kickerandy
Vesta, MN America
Post Number: 15
i have a kicker 10" L7 and i was wondering what would be the loudest.....slotted or round? and what size should i make the port, and what should be volume of the box???? need help.....specs would be very nice!!!!!
Username: 54danny54
Betsy layne, Kentucky..GO... USA duh
Post Number: 1965
slot or round port really isnt louder than eachother
with ur sub, go with 1.5-2 cubes tuned to 35Hz
Username: Tdbdadrummer
Wellsburg, WV USA
Post Number: 1474
Sometimes port noise is increased when you use a tube/round port. It depends on the quality of the enclosure though, noise is usually only a factor on a cheaply made enclosure.
I personally like round ports for home speakers, and slot ports for car audio useage. AKA my new car enclosure will have a slot port, and my CV V-12F's have dual 4" ports on each speaker lol.
Username: B101
Queen City, NC USA
Post Number: 1661
slot passes considerable more amount of air, greatly reducing any noise what so ever.
Wellsburg, WV USA
Post Number: 1482
Still, the noise is based of the quality of the enclosure.
I have a pair of cheapy Pioneer bookshelf speakers, and the round ports make all kind of racket, my CV's have the dual 4" ports, and make no noise at all!
It's all on the build...
Username: Safe_cracker
Chicago, IL US
Post Number: 397
Tyler you are right, if is is designed properly with the right sized ports, port noise will be at a minimal. Slot porting works at a much smaller frequency band compared to round ports and if you use Aero's they will be louder then any other. Most port noise comes from when a port is too small for the driver, or enclosure volume causing increased velocity and with the sharp edges of the port catching the air causes noise, Aero ports eliminate this allowing a higher SPL capability. Oh, slot ports make noise too.Polo.. :-)
Username: Rovin
Trinidad & T...
Post Number: 6479
hey my 3" pvc ports have NO port noise i can hear ......
Username: B101
Queen City, NC USA
Post Number: 1667
yea any design can make noise, if designed incorrectly. Aero ports are the best I think! Also the loudest!
Vesta, MN America
Post Number: 17
what exactly is an aero port?? round or what???
Username: 54danny54
Post Number: 1979
yea its round and from my understanding, its just flared, rather than have an edge like pvc
Vesta, MN America
Post Number: 18
so insead of jsut stopping, its kinda smooth lookin??and at the end it flares out???is that on the inside too?
Username: 54danny54
Post Number: 1980
not the inside but at both ends its flared for minumal port noise
Vesta, MN America
Post Number: 19
both ends???......could you make teh port or would u have to buy them??do u know a web site that i can go to taht will give me an example of the aero port??
Vesta, MN America
Post Number: 20
both ends?? can i make the aero port or would i have to buy it??and is there a site i could go to that will give me an example of an aero port?
Username: 54danny54
Post Number: 1981
u could make one but i think it be kinda hard.
Wellsburg, WV USA
Post Number: 1496
Well, my friend has flared ports on his Audiobahn Bandpass setup (the one that's coated black with the flames and 800W RMS).
It sounds like garbage...Plus he keeps the HPF on a lot, and it sounds worse. I had to ride with him today somewhere for like 30 minutes...It about killed me.
Vesta, MN America
Post Number: 23
ha so your saying dont get the flared ports???
Wellsburg, WV USA
Post Number: 1521
No no, I'm saying prefabbed bandpass enclosures for the most part suck lol. Nothing to do with the port, just the enclosure design.
Vesta, MN America
Post Number: 24
haha ok, but what do u think, round or slot port what would be the best
Wellsburg, WV USA
Post Number: 1522
Slot porting is easier to design IMO. Both work well though.
Vesta, MN America
Post Number: 25
IMO???? whats that..........would i get the same loudness, and sound quality??
Wellsburg, WV USA
Post Number: 1525
In My Opinion.
Most likely. The differences would be subtle as long as port area is the same.
Vesta, MN America
Post Number: 27
ok, thanx alot, but another thing...does it matter where i put the port...like on the top or the side????
Username: B101
Queen City, NC USA
Post Number: 1688
yea port placement is critical.. when it comes to spl..
shooting ports backward and aimin subs upward is known as a CRX design... it yeilds the most output...
Vesta, MN America
Post Number: 28
so is the sub and port on oppisite side of the box??? and were u talkin about slotted or round?? round right?
Vesta, MN America
Post Number: 29
what should i tune it to......sumwhere around 30 - 35 Hz????
Chicago, IL US
Post Number: 414
External Aero ports boost SPL a bit more.(in background)
Username: B101
Queen City, NC USA
Post Number: 1691
I was talkin about Aero ports, like what Polo got there...
Ports facing toward trunk(back), subs firing upwards(top), yeilds the most SPL most of the time!!
tune box around 30-35 for sound quality!
35-50 for pure spl, yeilds way louder score on mic!
Username: B101
Queen City, NC USA
Post Number: 1692
here is a alot brighter pic of his box...
Vesta, MN America
Post Number: 30
if just put regular PCV pipe in my box do u think it would be good??
Username: B101
Queen City, NC USA
Post Number: 1694
PVC pipe can work, as long as its the correct length and diameter to match the box tuning freq.
Vesta, MN America
Post Number: 31
ya polo looks nice>>>>>>what is it......but i have a silverado,but ya i was goona go with PCV or slot port......
for size reasoning, would PCV be smaller.....probly ya, and do you get the same quality??
Username: Jprix82
Post Number: 338
Is a CRX box just like a regular round port vented box but with the ports inside out?
Username: Rovin
Trinidad & T...
Post Number: 6511
pvc port calculator >>>
http://www.the12volt.com/caraudio/boxcalcs.asp
Username: B101
Queen City, NC USA
Post Number: 1700
as long as any type of port is tuned to the same freq, its should yeild the same quality!
slot port, is normally as long as the box itself..
a CRX box MUST have the subs facing upwards, pointing to the ceilng... the aero ports must be facing backwards, but some people have done it forwards.
Username: Jprix82
Post Number: 339
OK so lets say i have a regular areo ported box tuned to 35hz so if i fliped the ports inside out and pointed them backwards and the subs up i will have a CRX box?
Username: B101
Queen City, NC USA
Post Number: 1701
yepp, it will also be louder too..
Chicago, IL US
Post Number: 417
Larger box+more ports+more frequency+more power= More louder, lol. B your right about the upward firing, rear port box but mostly in like Hatch backs and SUVs. In a trunk vehicle it tends to lose a little energy due to the flexing trunk lid. To gain the most enery possible from your ports I recommend them to be 90deg angle from the sub. I could run these ports internal with a small loss but it looks freaky for sure.Here is what Aero port ends look like. Polo..
Username: Jprix82
Post Number: 341
will it be better for low tuned boxes?
Vesta, MN America
Post Number: 32
so how do you "tune a box" do u just set ur Hz level on your amp to what u want??
Chicago, IL US
Post Number: 426
Here is an example of the box B is talking about, I think....Polo..
Username: Jprix82
Post Number: 342
Username: Jprix82
Post Number: 343
Hey B/Polo does CRX style box work good(louder) for low tuned boxes
Username: Nissankicker
Grambling, LA USA
Post Number: 13
Me, personally, I'd go with a slotted port... tubes don't blow as hard... make it tuned at 30hz-40hz.. @ 1.5 - 2.3 cubes...
Username: B101
Queen City, NC USA
Post Number: 1735
hell yea...
man, the CRX box I heard shook the inside of my head, that how freaking lOOOOOOOWWWWWWWWWWWWwww it was man! but that was a KILLER system!
4 TSX 15s, 10 Aero ports, with covers to change tuning.. it was SICKKKKK
slotted is nice, but my next box is going to be Aero ported low, like 28-30.. I just loved how that thing sounded. and if u think Aero dont push out as much air, then u wrong....
Grambling, LA USA
Post Number: 15
I just don't like tubes... They remind me of a freakin' Bandpass box... you know! the faggit one's w/ the Plexiglass like crap in the front! HAHAHAH!
Chicago, IL US
Post Number: 427
Then you will always be that person in front of me wondering "who's playing all over my sounds", lol.. :-O Polo..
Grambling, LA USA
Post Number: 16
HA!.. Trust me... you'll never play over my sound! You must be crazy...
