Need Help
Username: Nypdlapd
Post Number: 45
My brother rewired his headunit and the ground and constant 12 volt wire touched.. but the wireharness was not connected to the H/U.Now the H/U does not turn on. what do i do to make it turn on??
Username: Nypdlapd
Post Number: 46
do i need to rewire the ground?? or the constant..
Username: Nypdlapd
Post Number: 47
i no it is not the headunit..
Username: Illuminator
Post Number: 2733
Check the fuses before doing anything else. If they are all fine, you probably need to hook up the ignition wire as well to the head unit.
Username: Nypdlapd
Post Number: 48
i did hook up all the wires
How do i no if the fuses are dead??
Post Number: 2734
Check every fuse on the main fuse panel, specifically the radio fuse.
Post Number: 2735
The metal piece between will be broken and/or they'll be blackened:
Username: Nypdlapd
Post Number: 49
all the fuses are good
i think it is the ground wire because the Ground TOUCHED THE +12 VOLT
Username: Nypdlapd
Post Number: 53
Is it the ground wire or +12??
Username: Theelfkeeper
Stockbridge, GA USA
Post Number: 1341
try running another ground or +12 and see. or use a meter to figure it out. no other way to tell. that should have just blew a fuse though. i have 2 fuse boxes in my car, one in the car and one under the hood. sure you don't have more someplace else??
Username: Nypdlapd
Post Number: 55
I have a 1990 chevy astro
