What are "Cheater amps"
Username: Jprix82
Post Number: 286
Username: Mikechec9
Http://www.cardomain.c...
Post Number: 2225
Not sure about the new bucks, but it's always meant an amp rated at a particular rms that produces a considerable amount more in reality. This allows competitors to enter a certain class, but have more power than most others. In essence "cheating." RF used to be really notorious for their underrated amps. they still underrate by the widest margin on avg that i've seen.
Username: Tjmutlow
Post Number: 1608
It does not matter much anymore for comps, they have changed how classes are ratedn MECCA uses fuse rating 18" from amp.
Username: Winterfreshpimp
Chisago, MN America
Post Number: 13
my friend has an amp that 1x40 watt RMS at 4ohms 1x750 at 2 ohms and 1500x1 at one ohm... im pretty sure thats what it means but i dont know for sure
Username: Usask8er1
Appleton, Wisconsin USA
Post Number: 65
Orion and Earthquake used to put out some of the best cheater amps. Some of there older amps would be rated in the 300 watt class and be pushing almost 3000 watts.
Username: Carguy
Post Number: 5377
If you want the "cheater" amps, take a look at Orion 250G4 or 275G4 amps.
It's rated 50w rms x 2 @ 12v. You'll get 100w rms or more in the car.
