Hifonics amps
Username: Beetleboyz2005
NC Usa
Post Number: 27
im asking to see if any of the hifonics amps are any good
Username: Texas_bass
Houston, TX
Post Number: 291
yes a good buget amp
Username: Fandim
Reno, Nevada United State...
Post Number: 802
Yes, they dont put out their rated power, and have severe drop offs at less than 14volts, though. Just make sure to have an adequate charging system, and you'll be fine. :-)
Username: Akula_class
Post Number: 17
x3 They are very good quality amps that won't kill your wallet. And will normally give you the power you need or very close to it.
Username: Theelfkeeper
Stockbridge, GA USA
Post Number: 1287
70% of their ratings is what i hear.
Username: Terry6405
Sullivan, IN US
Post Number: 536
i have a BX1205 i will sell you if you want it because i am upgrading to a nine 1 and i need some $$
i also bought an exchange warranty with it at fry's (big electronic and computer store) but i dont know if its transfurable or not and that store is about 2 hours away from me so replacing it might be costly, but hopefully thats not a problem.
id say it puts out about 850-900 real RMS watts
make me an offer but i was hoping for about 150 plus shipping. (exact amount of actual shipping, i wont screw ya on it, should be like 15 bucks)
i paid over twice that with the extended warranty but later i found
you can check it out here
https://www.ecoustics.com/electronics/forum/car-audio/205817.html
thats mine
heres other specs
http://www.sonicelectronix.com/item_3533.html
while im at it i might as well advertise the subs im selling because i got my SX15
the are the new vmax 12.4 12"DVC 600watts RMS
and i do have a transfurable warranty on those with well almost 2 years left on it
check that out here
http://www.caraudio.com/forum/showthread.php?t=146243
they are good subs and with the amp made a pretty strong system
if you bought both subs and the amp i would cut you a major deal and shipping would be cheeper as well
Username: Terry6405
Sullivan, IN US
Post Number: 537
i guess i got side tracked
b4 the first link it should say "but later i found out i overpaid
Username: Terry6405
Sullivan, IN US
Post Number: 539
actually i am selling that box that the vegas are in too its about 1 cu ft after displacement and tunned to about 39hz (roughly to the specs of the vmaxes
and i built a box for a sx12 but then got a sx15 so im selling that too no carpet on it though but i guess that means that you get to pick it, its 2.5 cu ft tuned to 32 hz
