Wiring for 92 tuarus sho
Username: Kerryb01
Spartanburg, South carolina Spartanburg
i have a 92 tuarus sho and i cant figure ou which speakers wires are pos and negative for the front and rear speakers,could some one give me som info,,
Username: Nypdlapd
Post Number: 72
Right Rear Spkr (-) Blue Purple w/ Black Stripe
Right Rear Spkr (+) White w/ Blue Stripe Purple
Right Front Spkr (-) White Gray w/ Black Stripe
Right Front Spkr (+) Blue w/ White Stripe Gray
Left Rear Spkr (-) Red w/ Blue Stripe Green w/ Black Stripe
Left Rear Spkr (+) White w/ Blue Stripe Green
Left Front Spkr (-) Blue w/ Orange Stripe White w/ Black Stripe
Left Front Spkr (+) Purple White
Ground Wire Black
Dash Light Dimmer Wire Orange
+12 Volt Ignition Wire Red
+12 Volt Battery Wire Yellow
Hope this helps!!
Username: Kerryb01
thanks for the info
Username: Kerryb01
what size speakers do i replace for the front on the 92 tuarus sho,i know the back is 5x7 but not sure for the front if they are 5 1\2 or 6 1\2 inch ,that info would help me out,,,
Username: Nypdlapd
Post Number: 80
They should be 6-6 1/2"
Username: Kerryb01
okay thanks again for the info,,
Username: Nypdlapd
Post Number: 86
np
Username: Tjmutlow
Post Number: 1644
they should be 5x7
Username: Tjmutlow
Post Number: 1645
sorry, 5.25 or 6
Username: Nypdlapd
Post Number: 91
OR 6 1/2
Username: Kerryb01
my 92 tauras sho colors do not match the colors that were given to me ,i need the correct factory speaker colors for the front and rear speakers,,any new info?
Username: B101
Queen City, NC USA
Post Number: 1857
get a wiring harness, it has your color code on it!
or R u straight wiring it?
Username: Kerryb01
each speaker wire has 2 wires connected to them so im looking at 8 wires a speaker harness does no have that many,,
Username: Nypdlapd
Post Number: 114
Do u have the audio package??
Username: Kerryb01
Post Number: 7
i think so
Username: Nypdlapd
Post Number: 116
Oh the wires are different!!
Username: Tjmutlow
Post Number: 1676
at the radio, is the speaker harness a little square black plug? and the other a grey plug. it is the ford premium harness, and the speakers may have 2 positives and 2 grounds on them, but it will still only be 1 wire at the harness.
Username: Kerryb01
Post Number: 8
okay but how do i determine which wires are what when i remove the rear speakers and the door speakers,they have the factory pigtails on them,i have to cut them off to and put new ends on them to make them fit on the new speakers,i bought some infinity door and rear speakers,,
Username: Tjmutlow
Post Number: 1681
look at the speaker itself, it may be marked, if not what is the colors at the speaker. does it look like 1 wire, with a split of 4 wires off it into the pigtail.
