Orion 2400d with L7's question need help
Username: Steven132221
Post Number: 24
i have a new L7 2 ohm what is 2000 watts max. could i run a orion 2400d amp with it even though the amp has more wattage than the sub. i will be running it at 1 ohm.
Username: B101
Queen City, NC USA
Post Number: 1395
it will be okay, its actually perfect!
Username: Jakeyplaysbass
St. Louis, MO
Post Number: 619
thats alot of power for an L7. u could get the 1200d and it will power it more than enough.
Post Number: 26
so with my two L7's hooked up to two orion 2400d (the west coast custom amps) would not blow the subs even running at one ohm? would i just turn the amp down some?
Username: B101
Queen City, NC USA
Post Number: 1397
oops
listen to jake, L7 only 1200rms.... oooo
only use RMS numbers!
Username: B101
Queen City, NC USA
Post Number: 1398
ohh, those wcc customer amps go by max ratings, so still you should be fine. the wccd2400 is a 1200rms amp! u need to only use RMS numbers!
St. Louis, MO
Post Number: 623
look on ur other post.
Post Number: 30
should i go with two orion 2400d's or two directed 2400d's?
Username: Johnnylemoine
LaPlace, Louisiana United States
Post Number: 577
orion doesnt make a 2400D amp. they have a few smaller amps, but the big ones are 1200D and 2500D, they call the WCC amp a 2400 watt amp becuz it is 2400 max which is not as important as the RMS its just to make ppl go, "ooo 2400! thats more than 1200!!" but really its just an orion 1200D. i have one.
Post Number: 45
2400d as in the west coast customs amp only puts out 1200 watts total or 2400 total?
Post Number: 579
2400 total but that number is irrelevant. 1200 is the number u need to know.
Post Number: 56
ic ic
