NEWBIE broke my head unitt
Username: Kingtks
ok here is the deal. i bought 4 new pioneer speakers and a headunit. the speakers worked great. then i went to install the head unit i did it to the best of my knowledge and i got it to work. i was so happy everything was perfect on the first try. well when i tried it the dash still wasn't put together and i realized the antenna wasn't plugged in. so i took it apart and plugged it all in again and now the head unit will not turn on. i also noticed my stock clock in the dash isn't working. i own a 91 celica coupe by the way. so i know nothing of cars and what i've gathered from others is i probably blew a fuse. but i have no idea where that fuse is. i checked a bunch and they looked fine unless i'm looking in the wrong spot. any ideas?
Username: Audioguy22
Post Number: 204
You should get your power from a clean source(like the battery).
Does sound like a blown fuse thoe.
