Which sub should i choose
Username: Langless28
Post Number: 317
which sub would be better i have the polk momo mm2124 right now. IF i upgrade, should i get the mm2124 DVC version or the infinity 12.1d. i want a DVC sub so it would be getting more power closer to it power requirement. and other sub reccom. would be great too! around $175 bucks new and its gonna be in a ported box.
Username: 54danny54
Betsy layne, Kentucky..GO... USA duh
Post Number: 1849
12 inch RE SE? maybe
assasin...stay away from polk...also that infinity be a good choicde too
Username: Ironslave
Post Number: 51
yea i would go with the infinity too
Post Number: 319
on another post u said the infinity is better in a sealed box. how bad would they sound in a properly set up ported box
Username: Ironslave
Post Number: 54
well... the are too loose..too much boom, a lot of lingering on the really heavy stuff. SQ was still Ok though
in a properly setup ported box the SQ would be good... as ive heard them.. but the SPL would be kinda disapointing though.. in my opinion
i didnt see that part about ported.. in that case i would probably go with something else...
but this is all based on the 1230w Reference the only ones ive used... I Love em sealed.. they sucked ported though... but these are nowhere near the Kappa's Quality
Username: Ironslave
Post Number: 55
and like he said stay away from polk
Post Number: 320
why do you say stay away from polk. just for learning purposes. i have one right now ported. sounds ok but if the kappa perfect is better in sq and spl ported, then ill get that
Username: Rovin
Trinidad & T...
Post Number: 5878
Look @ Image Dynamics IDQ series - reported 2 have gr8 SQ if thats what u want ......
Post Number: 321
ok i was looking for sql but more on the sq side but i do want it to be louder than all my other fiends, since im the car audio guru to them (not bragging. im still learing, just faster than they are)
Post Number: 322
also is the infinity kappa perfect 12.1d the best bang for the buck? round $175 for one. or is their something that out performs it for less $. not a big fan of used stuff either. although i did get a 300/4 off ebay for like 125. got it tested and i love it for my components.
Username: Ironslave
Post Number: 56
yea if your looking for great SQL dont get a 1230W infinity reference.. thats all i can say... sorry but i know nothing about the kappa when they are ported....
hmm i gotta think of a good idea for you... whats your box specs? (square feet port dimensions)
Post Number: 325
for the kappa 12.1d i was going for a traezoid box type to go flush with my backseat. 1.5 cf and a port tuned to 32-33 hz. i want to keep the box size relativly close to 1.5 too. due to space.
