Capacitor
Username: Ironslave
Post Number: 43
ok im just curios about this... but what is the purpose of a capacitor?
never used one never really was wondering about em either
Username: Eeater
Post Number: 34
it helps regulate power needs when it hits hard, and it levels stuff out ont the battery or something..
Username: Rovin
Trinidad & T...
Post Number: 5857
take a read
http://wickedcases.com/caraudio/capacitors.html
Username: Ironslave
Post Number: 44
ok so the use of the capacitor is to make your electrical supply smooth.. preventing spikes...
i am having an issue with my car and was just wondering what the issue could be... my cars lights dim and the RPMS loose about 1-200 RPM when bass hits... but only when the car is parked or stopped... it runs stable other than that... so i dunno if i need a better alternator...
would a capacitor also reduce clipping?
Username: Theelfkeeper
Stockbridge, GA USA
Post Number: 1145
a capacitor won't help if you don't already have an adequate charging system. you should look into getting a HO Alternator.
Username: Greeney1888
Maple Grove, MN United States
Post Number: 155
http://www.wickedcases.com/caraudio/capacitors.html
http://www.wickedcases.com/caraudio/charging.html
http://www.betteraudio.com/geolemon/newmain/battcapalt/
http://www.bcae1.com/charging.htm
http://www.bcae1.com/chargin2.htm
http://www.wickedcases.com/caraudio/batteries.html
http://www.the12volt.com/info/recwirsz.asp
http://www.optimabatteries.com/
Username: Eeater
Post Number: 64
I would take Greeney1888 advice
It sound like you might have lowered your battery to low too many times, and deepcell batteries are beter than a capacitor b/c if you do get a HO alternator you would want a yellow top too, right?
