Dvc subs can somewone explain?
Username: One_loud_vett
Belmont, NH Usa
Im thinking of buying a rockford stage 3 10".It has dual 4 ohm voice coils ,what does this mean to me?If I want to run it at 4 ohms will I only take advantage of half the watts if I hook up one voice coil,and if I hook them both up from the best I can tell Id be at 2 or 8 ohms.If I run it at 8 ohms Ill only be drawing half the amp power,what if I run it at 2 ohms?If the amp is 2 ohm stable is this the way to go?Any help is appreciated.
Username: Eeater
Post Number: 66
Those subs are junk they break easily.
how much money are you working ith?
Username: Eeater
Post Number: 67
DVC means that it ha 2(+) and 2 (-).
but it goes much deeper than that..Upload
