Phoenix Gold or JBL?
Username: Paogr
AthensGreece
I'm looking for a small cheap sub and i'm between PG Octane-R 12 and JBL GT4-12 both 250wrms. Which is better? The Infinity Reference 1240W (300wrms) is much better from those? My amp is 1x160wrms bridged.
Thanks...
Username: Ctmike
Post Number: 11
yasas!
i'm fairly new to car audio to, but i would go with the jbls'. i had an older pair that sounded pretty decent for the price and lasted a long time. don't know your budget but if thats the amp you plan on using try a jl w0 sub it'll perform better with the power your amp puts out.
Username: Hootz
Saskatoon, Saskatchewan Canada
Post Number: 99
I'd go with the PG.
Username: 54danny54
Betsy layne, Kentucky..GO... USA duh
Post Number: 1799
JBL definatly.
Username: Rovin
Trinidad & T...
Post Number: 5814
i say screw both those choices & get this instead...
http://ascendantaudio.com/assassin12specs.html
Username: Paogr
AthensGreece
Thanks guys. Rovin i can't find assasin subs anywhere in my country. Possibly i will go with the JBL.
Should I buy the JBL 1200B or build my own box?
Username: Mrbass
Long beach, California United state
to be honest i say pg is the way to go, but knowing that jbl is been in the market for decades now, but i had a pg 10inch xenon and it bump pretty hard at 450rms
Username: Mrbass
to be honest i say pg is the way to go, knowing that jbl has been in the market for decades now and it should be better but i had a xenon pg 10inch and it bumps at 450rms
