RCA Voltage question.
Username: Safe_cracker
Chicago, IL US
Post Number: 277
I am running a Kicker sx1250.1 mono amp. I measured my head units rca voltage and it comes to be 3.93V each L/R now because it is a mono amp is the L/R voltage combined or is it a total of 3.93V? The reason why I ask is becasue if I unplug one side it gets quieter so I figured they wouldbe internally combined and I need to set the input range correctly. Polo..
Username: Frobro
Whitehall , MT USA
Post Number: 20
the higher the voltage is off of your head unit the beter sound quality it will have so just set the amp to like 4 volts its a mono amp so you do the semple thing and put them both to 4 volts and it will sound great
