New Type R Ported
Username: Jbump
Nebraska City, Nebraska USA
Post Number: 105
Just made this box today, My first ported box, 1.67 cu.ft. tuned 35Hz 3" port rounded at the back, Carpet wasn't good enough for the Braggin Area, Test run on how that rubber on the back dampens it.. Upload
Username: Efil4zaggin
Chi Town, IL Cook
Post Number: 163
Y is it fucked^
Username: Lexuscoop
Post Number: 871
what? how'd you get that across censorship?
Chi Town, IL Cook
Post Number: 165
its magic!!!
Username: Jbump
Post Number: 106
What you mean fucked^?
Los Angeles, CA USA
Post Number: 2511
lol you can't say p!mp on here but you can say fucked. lol. that is fucked up.
Username: Tdbdadrummer
Wellsburg, WV USA
Post Number: 1343
It's probably because he has the "^" after it...Making it look like one big word...
Username: Greeney1888
Maple Grove, MN United States
Post Number: 110
fucked
^ worked and i dont need the ^ after it
Wellsburg, WV USA
Post Number: 1348
Ok, then the Admin. on here are crazy!
Username: Jbump
Post Number: 108
What do you mean Fucked^?
Username: Jbump
Post Number: 109
oops, sorry bout double post..
Chi Town, IL Cook
Post Number: 171
its kinda dirty!!!
Username: Jbump
Post Number: 110
Yeah, I don't care, old carpet layin around so i used it.. actually, its pretty d@mn loud.. kinda of have a head ache after driven around for 30 mins..
Username: Dustin3
Tigard, Or U.S.
Post Number: 439
"what? how'd you get that across censorship?"
so if you posted something with the word P!mp in it, and ytou try to post it, will it not let you??
Username: Pelona
Post Number: 693
fucked
Username: Dustin3
Tigard, Or U.S.
Post Number: 440
ok i c, nm
Username: Pelona
Post Number: 695
i cant believe they censor p.uta but not puto
Username: Jbump
Post Number: 111
PUTA,FUCK, those work.. hold alt and push 0220 on the num. pad...
Username: Nemen
Trinidad & Tobago West...
Post Number: 232
that's a pretty nice box for your first time.
Username: Rovin
Trinidad & T...
Post Number: 5720
Damn ! - that box is almost exactly like mine .
https://www.ecoustics.com/electronics/forum/car-audio/189456.html
Mines 1.65 cu ft 3" pvc & ported 2 35Hz also ! - do ur self a favor & build 2 of those .....
Username: Rzarector
Coquitlam, Bc Canada
Post Number: 933
3" pvc seems kinda small for a type r.. you guys arent getting any port noise?
Chi Town, IL Cook
Post Number: 172
fUck U
Chi Town, IL Cook
Post Number: 173
just testing
Username: Jbump
Post Number: 114
Thanks Rovin, Kinda got the idea from you, didn't wanna ask around, hope ya don't mind, sept i added the displacement .071 to the net cu.ft for gross volume 1.741 to get the exact measurements and port length to all turn out perfect...I need 2 Type Rs first, Thinkin about either getting another Type R with my taxes or a sh!t load of Edead v.1 and v.3 hard decision, this box makes the R shake the sh!t out of everything..*awesome box Rovin*, lol like when i parked next to my friends boniville this morning he freaked when his antenna was shakin everywhere..btw, i rounded the back of the port, so i don't get any port noise, but i put it facin up in my trunk, the air blowin on my ear kind of irratating after a while..
Username: Rovin
Trinidad & T...
Post Number: 5744
"btw, i rounded the back of the port" - Dude ! thats exactly what i too did when i built mines ! & i too do not get any port noise ....
I seriously gotta get some deadener 4 my trunk also .
No problemo - glad 2 help
Check back my install thread (i just added something but the damn thread won't bump) - u will now know what amp 2 get ......
Username: Jbump
Post Number: 116
Whats your opinion Rovin, another Type R, or some Edead? i dunno if my little grand am could handle the spl of another Type R.. but it be sooo freakin loud.. I think i'm kind of leanin tward another Type R...What a sucky, some what of a delimma...can't really compare the Type R to Edead.. lmao..
Username: Safe_cracker
Chicago, IL US
Post Number: 265
In order to eliminate all port noise you nead to have a conical shape on both ends of the port because the air moves both in and out of the port. Polo..
Username: Rovin
Trinidad & T...
Post Number: 5757
Jay B . - go ahead & get another R if it can fit .
When i connected that bigger amp 2 my 2 Rs it was REALLY Bumping kinda extreme & i disconnected 1 sub just 2 see how it will be & believe me 1 sub playing alone just doesn't cut it - u need 2 of those Rs 2 really appreciate it.....
FUCKED In The BUTT
Username: Jbump
Post Number: 121
Sorry to hear that anon.. anywho.. Rovin has inspired me to yet.. again! buy (another) Type R.. I think it'll fit.. i could slide one up father tward my back seat.. just hope i don't get a flat tire after that, them ported boxes are really freakin heavy, lmao.. Thanks for the Reply Rovin.. bump
Username: Rovin
Trinidad & T...
Post Number: 5818
Ya Jay B. - when u do get another R & power both properly u will thank me even more -lol
In upcoming wks i may buy a bigger amp & i wanna experiment with both sealed & slot ported boxes on my Rs - will post results in my install thread .....
Username: Jbump
Post Number: 127
Right now i have my R on one channle.. 1000wrms @ 2ohm and i don't wanna try and push it with one vc to both channles, 600wrms @ 4 ohm.. even though the amp is only half way up, i actually think this (crappy to some) Lanzar amp is rated pretty accurately.. but its running at 14.8v instead of 14.4.. But i plan on doing the big 3 soon, so i'll have to see how it performs then, and good luck on the new amp and boxes..
