Wiring?
Username: Bulldogsm2008
Iowa City, Iowa
Post Number: 49
how would i wire 2 dual 4 ohm or dual 2 ohm subwoofers to 2 ohms at the amp?
Username: Lexuscoop
Post Number: 934
you can't wire 2 dual 4ohms to 2 ohms
Username: Goatin
U.S.A
Post Number: 454
Is it a 2 channel amp?
Username: Goatin
U.S.A
Post Number: 455
http://www.rockfordfosgate.com/rftech/wiringwizard.asp
Iowa City, Iowa
Post Number: 50
no mono that sucks because i plan on getting 2 type R's and a mono amp but need to wire em to 2 ohm but i see that is not possible but was wondering if there is any way at all to do it
Iowa City, Iowa
Post Number: 51
ok i guess it is possible then
