Amp for Audiobahn Immortal
Username: L_welborn
Mississippi United States
Ok, I have a question. I need to know what kind of amp would I need for a 3000w max, 1500w rms, quad 2 ohm voice coil Audiobahn Immortal? I didn't know if I could use a mono amp or if I needed an amp with more channels because this sub has 4 voice coils? I'm sort of new to this stuff, please help!
Username: N2audio
Lawrence, Ks USA
Post Number: 604
quad 2's will get you 1/2 ohm, 2 ohms, or 8 ohms.
Most logical solution would be a big mono amp.
If it were me I'd probably go with a Lanzar Opti2000D for 1900w at 1/2 ohm. Be cautious with the gain and that sub should slam.
Username: Judgedredd
Post Number: 9
you should be able to wire them at 2ohms..in which case if you like audiobahn check out the
Audiobahn A4KDN
feel free to correct me if im wrong..good luck!
Username: Chaunb3400
Huntsville, Alabama U.S.
Post Number: 5771
electrical system upgrade would almost be a must
Username: L_welborn
Ok, thanks. That's what I was planning on doing is just getting a mono, but I wasn't sure about what I needed. Also, if I get an amp that's 1500w rms, I'd need a higher output alternator for my car too, wouldn't I?
Username: N2audio
Lawrence, Ks USA
Post Number: 639
Class D's are pretty efficient. Depends a lot on the car and your listening habits. People have run that much power on stock charging systems successfully, but there have been problems with less.
