Need to buy Sub Box, are these reviews legit?
I'm buying a sub enclosure this week and wanted to know your guys opinions on this
"Bass Slammer Dual 12" Unloaded Vented Enclosure"
http://www.circuitcity.com/rpsm/oid/119725/rpem/ccd/productDetailReview.do#tabsp roductDetailReview.do#tabs
I also got a couple of other questions...I'm also considering to just build a sealed box. How much would I be out for just the materials (no tools)?
Can I get a list of materials needed? What type of wood is the best? Thanks
Forgot to mention, if it matters. My setup is
2 12'' Infinity Reference
1 1000w Crunch Amp
Username: Southernrebel
Monroe, Louisiana USA
Post Number: 2239
3/4" MDF (wood) ---$25
caulk---$2
1 5/8" deck screws---$5
wood glue---$5
other than tools...thats all you would need. one sheet of MDF is 49"x 96"...you would have enough for a ported box if you wanna tackle building one. (not hard at all...just gotta have some wood working skills)
if you want to build a ported box...email me:
marshall_white2004@yahoo.com
i'll give you a cut-by-but guide for what ever subs you have for $10.
resx
49x97***
