Lead me in Right direction
Username: Nyrider
Rochester, NY
Post Number: 11
I need a 750 rms, 4 ohm operating, best suited for sealed enclosure, fast bass hitting like a kickdrum, rap techno bass, SUBwoofer. Can you HELP me. Before I had AudiobUrn but now I have enough to upgrade to better. Looking to spend at the most $250 on it. I am puttin it in a acura tl it has a rather small trunk so can you recomend me one that use's a a small cubic ft enclosure but if you cant thats ok. I think that should cover it but if you need anymore info let me know I REALLY NEED YOUR GUIDANCE as my expert lead me to AUDIOBuRN :snipe:
Thank you
Username: Chaunb3400
Huntsville, Alabama U.S.
Post Number: 5755
Crystal Comp
Username: Tdeaton1021
Near Tampa, Florida USA
Post Number: 1980
yup that would be a good buy. heres a link for ya.
http://www.realmofexcursion.com/store/product_info.php?cPath=21_60&products_id=9 2
Username: Nyrider
Rochester, NY
Post Number: 12
thanks guys
Username: Nyrider
Rochester, NY
Post Number: 14
those are 500 watt rms my amp puts out 800w rms really 750w is that going to be ok?
Username: 54danny54
Betsy layne, Kentucky..GO... USA duh
Post Number: 1780
just dont go trigger happy with the volume knob lol...or u can go with the RL-s www.soundsplinter.com
(note that it might not sound the best due to the large ported size, yet i heard it can be pretty good in sealed boxes)
Username: Nyrider
Rochester, NY
Post Number: 15
Would this one be better http://cgi.ebay.com/Crystal-12-Competition-Subwoofer-1000W-Max-COMP12_W0QQitemZ5 826927017QQcategoryZ18805QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
12 inch 600 watts rms
Post Number: 5761
there website say a conservative 600 rms for the 10"
so 750 should be ok
Username: Nyrider
Rochester, NY
Post Number: 16
Would this one be better http://cgi.ebay.com/Crystal-12-Competition-Subwoofer-1000W-Max-COMP12_W0QQitemZ5826927017QQcategoryZ18805QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
Username: Nyrider
Rochester, NY
Post Number: 17
sorry about the double post
Post Number: 5763
same sub just the 12". there website say it is rated at 700 rms, bigger is always better
Post Number: 1990
both would be fine
