Does this look ok for a SX12
Username: Terry6405
Sullivan, IN US
Post Number: 322
when RE says that a 12"sx should be in a 1.9 cu ft box tuned to 32hz does that 1.9 include or disclude the port and sub displacement? in other words sould it be 1.9 cu ft total? or bigger?
this is what i was gonna do
http://www.accelerator-pedal.com/ported-box.asp?Ew=32&Eh=16&Dia=6&Xmax=21&Vd=0.1 6&NumW=1&Vb=1.9&Fb=32&Qts=&Vas=&Fs=&CE=0
look ok?
or i might tune it to 30 hz
http://www.accelerator-pedal.com/ported-box.asp?Ew=32.5&Eh=16&Dia=6&Xmax=22&Vd=. 16&NumW=1&Vb=1.9&Fb=30&Qts=&Vas=&Fs=&CE=0
or mabey even this?
http://www.accelerator-pedal.com/ported-box.asp?Ew=32.5&Eh=16.5&Dia=6&Xmax=21&Vd =0.16&NumW=1&Vb=1.9&Fb=30&Qts=&Vas=&Fs=&CE=0
what do you think?
would they work?
which is best?
i like the last one because of some simple measurements
what do you think?
Username: Tdeaton1021
Near Tampa, Florida USA
Post Number: 1875
i like the top 2 because they have slighly more port area. they all work though. that is the kind of 1.9 cuft they are tlaking about. except, well, find out what the woofer disp. is and add that to 1.9. then say the disp. was .15cuft(i dont really know) set the net volume to 2.05cuft and choose wether you want 30 or 32 hz tuning.
Post Number: 1876
well thats according to their specs. but however i would do like 2.25-2.5cuft instead of the 1.9
Username: Yukhui
Myrtle Beach, South Carolina USA
Post Number: 141
What would be the perfect box specs for this sub?
CuFt- ?
Tuning- ?
Username: Yukhui
Post Number: 142
didnt bump
Username: Yukhui
Post Number: 143
STILL DIDNT BUMP!!
ahhhh
Username: Safe_cracker
Chicago, IL US
Post Number: 226
Ummmmm, I'm thinking that 30hz is too low. In car the frequency will tune much lower thus you will be losing quite a bit of amplifier power to absorbtion. JMHO...Polo. :-)
Username: Greeney1888
Maple Grove, MN United States
Post Number: 89
32hz should be good. im at 35 and i dont think im hitting evetrything so thats y im gonna either go 32hz or 30hz for my next box
Username: Terry6405
Sullivan, IN US
Post Number: 324
32 sounds fine to me, but sould i make it a little bigger than that? mabey like this
http://www.accelerator-pedal.com/ported-box.asp?Ew=32&Eh=16.5&Dia=6&Xmax=21&Vd=. 16&NumW=1&Vb=2.25&Fb=32&Qts=&Vas=&Fs=&CE=0
or if i wanted absolutely no room left in my trunk...
http://www.accelerator-pedal.com/ported-box.asp?Ew=32&Eh=16.5&Dia=6&Xmax=21&Vd=. 16&NumW=1&Vb=2.5&Fb=32&Qts=&Vas=&Fs=&CE=0
actually, that came out way simpler, i might just do that, barely any bigger anyways
ah, what-the-hell
http://www.accelerator-pedal.com/ported-box.asp?Ew=32&Eh=16.5&Dia=6&Xmax=21&Vd=. 16&NumW=1&Vb=2.75&Fb=32&Qts=&Vas=&Fs=&CE=0
what do you think about those, i like the last 2, but is 2.75 cu ft too big?
what do you think
btw
the drive displacement is factored in on this calculator
Username: Terry6405
Sullivan, IN US
Post Number: 326
this is what im goin with
http://www.accelerator-pedal.com/ported-box.asp?Ew=32&Eh=16&Dia=6&Xmax=21&Vd=.16 &NumW=1&Vb=2.5&Fb=32&Qts=&Vas=&Fs=&CE=0
but where should i put the sub?
i would think on the left side of the red board (next to the port) so the air circulates throught the whole box, but the single sub diagram on RE audio has it on the opposite side? does it matter?
Post Number: 1891
im not sure exactly what would be the difference, but everyone always does it on the oposite side of the port. i think thats where it would look best too, id just do it that way, on the right side.
Username: Terry6405
Sullivan, IN US
Post Number: 327
ok,
but i think i changed my mind on the box cuz i want a little more port area just to be safe
hows this look
http://www.accelerator-pedal.com/ported-box.asp?Ew=32&Eh=16.5&Dia=6&Xmax=24.75&V d=.16&NumW=1&Vb=2.5&Fb=32&Qts=&Vas=&Fs=&CE=0
i just made the xmax higher to get more port area,
if this looks ok thats what im doing for sure
Post Number: 1896
looks fine to me....
Username: Terry6405
Sullivan, IN US
Post Number: 328
i built it
Post Number: 1941
dammn didnt waste any time. did u listen to it yet?
Username: Terry6405
Sullivan, IN US
Post Number: 330
no the liquid nails has to dry, thats pretty much all i did today, actually i dont even have the sub :-) i just wanted to compit to it because if i didnt i would change my mind, cuz im an idiot.
it was fun building though, all i had was a circular saw and a drill so it was kinda difficult. came out clean considering that thought.
i think i might drop one ov my vmax's in just for fun tomarro
ill proble get the sub next week or so
Username: Terry6405
Sullivan, IN US
Post Number: 331
*commit not compit
after i get it carpeted or whatever i decide, i will probly take pictures of eveything and post it in the bragging section
COMMING SOON:
"The Teal-Mobile" --oldschool 89 accord
