Like
Please help build me a system
NeedSeriusHelp
Ok guys reading all the threads in this forum has showed me that car audio is not as easy as I think. So I was wondering if ya could help me. I have a total of $500.00 maximum to spend. I want to feal the bass in my chest what do you guys recommend. I know that $500 is nothing compared to what I've read but this is going to be my starter system and I just want to do It right. With your recommendations I think I cant loose. I have allready ran a 4guage amp kit threw my car into the trunk if that helps?
NeedSeriusHelp
Sorry By the way im going to put them in a 1997 honda accord 4dr sedan it has leather seats and I've read on here that muffles the sound a little bit. Im just confused over sealed versus bandpass, tuning,matching, I kind of understand the ohm configuration played around with the12volt.com wiring calculator. But still seems complicated and I only make 6.95/hr so going to a shop is definantly not an option. I also like the fealing when I do it myself. Any other information I can give to help?
jusvisiting
get two infinity reference 1240w at crutchfield for like $150 for the pair and get a two channel amp that puts out 200-300 watt a channel in a sealed box. wont be the best but with your budget it'll do.
NeedSeriusHelp
do you think ill be able to feal the bass in my front driver seat
Don't buy anything at "Crotchfield" unless you like getting ripped off. Do a search on the Internet and you can probably find what you are looking for at prices that are 25-50% cheaper than there.
Username: Chaunb3400
Huntsville, Alabama U.S.
Post Number: 5403
2 Dayton Titanic MKIII $350
1 Viper 1200.1 $125
U will feel the bass from all over ur car
Post Number: 5404
Do u want 10's 12's 15's
NeedSeriusHelp
I want to saty with 12's or 10's my trunk is really small I think the biggest I can fit is like 2 12's in a sealed box
Username: Jaked2ca
Lacombe, Alberta Canada
get some decent 6x9's and an amp..
youll have clarity and bass
maybe not in the chest but its
a good way to build up your system.
Post Number: 5544
get 2 of these
$270
http://www.partsexpress.com/pe/showdetl.cfm?&DID=7&Partnumber=295-404
1 of these
$125
http://ikesound.com/product-product_id/2424
and u still have $100 for box, wires, etc
one of these!!!
$150, 4000 watt 2chnl
http://www.cardiscountstereos.com/catalog%20page.asp?Product+%23=LA2268
2 of these
$180 2> 2000 watt subs 12"
http://www.cardiscountstereos.com/catalog%20page.asp?Product+%23=ALUM12N
one box...
$60
http://www.cardiscountstereos.com/catalog%20page.asp?Product+%23=ADRBP12E
and 1 amp kit
$25
http://www.cardiscountstereos.com/catalog%20page.asp?Product+%23=KIT4G
ALL TOTALS TO BE 4000 WATTS ..ANYWHERE TRULY TO BE 3000WATTS WHICH WILL BE FELT IN YOUR CHEST AND EVEN OUTSIDE THE CAR. NO MATTER ABOUT YOUR SEATS. TOTALS MONEY WISE TO BE $415 AND ADDING TAX AND S&H..ITS LIKE $440-$460. YOU WILL HAVE MONEY LEFT. THIS IS A GOOD DEAL.
Duuhhhhhh i like to update 3 day old posts as anon for no reason Durrrrr.....
Facebook
Shop Related Deals
Directory
