Is a 5 volt preamp any good?
James_Westlin
is a 5 volt preamp any good?and what is a pre amp?
Username: Terry6405
Sullivan, IN US
Post Number: 325
http://www.bcae1.com/
# 91 on the right of the page
yes 5 volt is good
Username: B101
Queen City, NC USA
Post Number: 1272
13v is better. But 5 will do great. =D
James_Westlin
what do they do exactly??
Username: Lbeckner
Tulsa, Ok Usa
Post Number: 622
generally the higher the voltage the cleaner the signal. your amp has to be able to handle it though.
