MY SYSTEM SUDDENLY TURNED OFF!
Username: Pelona
Post Number: 611
so this morning going to school i was bumping for a while then i lowered the volume. after like 2 seconds after i lowered the volume the subs suddenly turned off.
i checked the power, ground, remote, rcas, fuses on amp and the fuses on the power cable near battery. theyr all good. and my power isnt touching my ground either.
whats wrong?
Username: B101
Queen City, NC USA
Post Number: 1154
so what happened? the amp was still on? or in protect?
Username: Lexuscoop
Post Number: 791
check your fuse on your power wire, that happend to me too, that fuse is probably blown
Username: Pelona
Post Number: 614
the amp isnt even on. its in the same ground that i had it before so i know its not the ground.
and all the fuses are good. the ones on the amp and the power wire.
Username: Kaos15th
Post Number: 133
ya lo chingates fu4ken pelon.
Username: Pelona
Post Number: 625
ey. thats wut i thought. y apenas la compre.
Username: Clacla100
Tallahassee, Fl US
Post Number: 75
Sometimes the fuse on the wiring kit can look good but be burned up. Change it out just to make sure. Cause ive blown 4 fuses on my wiring kit. 3 of the 4 times the fuse looked like it wasnt blown. Also make sure all your ground and power connections are snug.
Username: Tjmutlow
Post Number: 1495
use a test light to see if you have power at the amp.
Username: Pelona
Post Number: 630
never mind. i just fixed it.
they took a look at it in the car audio shop. the fuse next to the battery blew.
it looked good if you look at it. but when he took it out of the fuse compartment, it was broken on the side where you cant see it.
i thought it was only the center that always breaks.
