Sub and amp confusion
I used a Bass tones test cd on my sub and after a while the whole system cut out, amp power light went of and all went dead. I changed the fuse from the amp (15) to a 20 and it is workin again. Any problem with changin to different fuse and likely to be any damage from orginal problem.
Thanks
Username: B101
Queen City, NC USA
Post Number: 1211
Register next.
But yea, it will mess something up by going to a bigger fuse on the amp! You need to figure out why did the fuse blow to begin with.
Maybe if you register you get more help.
