Wht kind of box
Username: Thegmayn
Orlando, Fl Usa
i got 2 12" audiopipes txxc1200 600rms a piece
i want to build my own box should i port it or leave it sealed
and which way would it hit lower and harder
Username: Ironslave
Post Number: 24
the subs would hit lower if you port... but it hits harder if you seal it....
it really depends on the sub... look up your diagrams and sizes for your subs...
also if you port it.. it will seem louder louder....
from my experience... ported is not worth it...
if you wand better LFS use sealed... it sounds way better.
