Hows this set up?
Username: Tommy23
im going to get a S15L7 kicker 2ohm Frequency Response: 18-100Hz
Efficiency: 88.5dB
Impedance: Dual 2 Ohm
RMS Power Handling: 1000 Watts
Peak Power Handling: 2000 Watts
and was wondering if this amp will be good with it? Power Acoustik A2400DB
Brand: Power Acoustik
Condition: New
RMS Power Output: 1400 Watts x 1 @ 2 Ohms
Signal To Noise Ratio: 100 dB
Frequency Response: 15-150 Hz
Bass Boost: 0-18 dB
Built-In Crossovers: LP
THD @ 4 Ohm RMS Power: 0.5 %
Low Level Input: No
Built in Cooling Fan: No
Bass Control Knob: Yes
Username: Tommy23
oh yeah right now i have the alpine deck cda-9853.. its in a 96 grand cherr
Username: Tdeaton1021
Near Tampa, Florida USA
Post Number: 1842
loud. not the best for SQ though.
what amp are you going to run it off of?
Username: Southern_bass
Paris, Tennessee U.S.
Post Number: 1623
he posted up there that a power acoustik
Username: Chaunb3400
Huntsville, Alabama U.S.
Post Number: 5489
should be loud, but not the best sq in the world.
Do u already have the amp or are u looking 2 buy
Username: Tommy23
im looking to buy a amp right now. thanks
Post Number: 5516
whats ur budget for ur amp
Username: Tommy23
umm well i dont want to spend more then 300 id say... from ebay or hifisounds
Username: Tommy23
i mean ill buy it anywhere but thoes are the cheapest places that i have found so far
