How much do get air conditioning??
Username: Dustin3
Tigard, Or U.S.
Post Number: 434
how much does it cost, just to go to your local pep boys or sumthin and have them charge your system with frion? i know it depends how much they put in, but around what price does it cost. i just need frion...
i am at school so i cant call them, so i am asking on here..
Username: Glasswolf
Wisteria, Lane USA
Post Number: 11078
I recharge the freon (refrigerant actually.. R34a) myself.. all you really need is a can of the stuff and a gauge to measure the line pressure.
costs me about $5 to do it if I recall.. had to recahrge the jeep a year or two ago.
Username: Glasswolf
Wisteria, Lane USA
Post Number: 11079
PS having them do it you're probably looking at about $200
they'll want to flush the lines and check for leaks before recharging the system.. which means labor.
Username: Young_james
Post Number: 807
It costs $100 CAD to do that around here at some local garage, but if you want a good job, like GW said, it will cost a fair bit of money.
Username: Rideredder
Cornell, IL USA
Post Number: 224
My uncle has a licence to do it. He installs it for free for us, but we have to pay for the freon. About $70 a can.
Username: Dustin3
Tigard, Or U.S.
Post Number: 435
200 bucks... no way. i heard it was around 100. their is no leaks in mine, and all of my hoses are already flushed out
Username: Dustin3
Tigard, Or U.S.
Post Number: 436
Username: Wojopro
Silverdale, WA
Post Number: 235
You dont need certification to handle R134A. You can buy it pretty much any local part store. I know I am universal card carrier. R12 you need to be certified
Username: Mrmikelazott
Independence, Oregon
Post Number: 76
bassman, im pretty sure autozone has it, i saw it at the the forest grove autozone. wasnt that much. hell of a lot cheaper than taken it somewhere
Username: B101
Queen City, NC USA
Post Number: 1083
r134a is like 2$ for a can! you need no more than 2 cans; go to the shade tree mechanic and have him charge it for 20$
Username: Atfdmike
Michigan
Post Number: 9
The R 134 a refrigerant is readily available at most auto parts stores. If your system still has some residual pressure, is short cycling or cools but not cold enough, chances are you need to add some refrigerant. The same auto stores sell recharge kits for little money with instruction on how to safely add the refrigerant to your system. You should first inspect the system to be sure you do not see oil leaking from joints, seals, etc and that there is some pressure in the system. Generally, if your compressor starts when you turn on the A/C and the ambient temp is 60 +, you know you have some pressure in the system, and it should be OK to add. You really should have a car thermometer to put in the outlet duct to monitor the amount to add. Getting the outlet temp to 40 or 42 F is a good thing. Some systems may push cooler, but if too much refrig. is installed, outlet temps go back up and the entire system can overpressurize. Todays systems do not generally have as much refrigerant as older systems, so adding a little and letting the system equalize will get you better efficiency than just adding a can willy nilly. Just trying to help.
Username: B101
Queen City, NC USA
Post Number: 1093
X2^^^
Listen to the man!
Username: Solacedagony
New Jersey US
Post Number: 811
Freon != R134a if I am correct?
Username: B101
Queen City, NC USA
Post Number: 1095
yea;
but its too cold to be talkin Air Conditioning guys... =D
Username: 420pimp2
Post Number: 425
bie the sh.it yourself and put it in yourself. Save $
