Wiring
Username: Jbump
Nebraska City, Nebraska USA
Post Number: 64
Can changing from 8 gauge to 4 gauge going from my cap to my amp somehow cause clipping or distortion? Or using a shorter piece of cable than before, I replace my cable with some 4ga. and it seems to sound different..
Username: Lexuscoop
Post Number: 675
8gage lets less electricity threw...
Username: Jbump
Post Number: 65
I know, but could more current change anything on the output?
Username: Lexuscoop
Post Number: 678
depends on the amp and the subs... if the amp isn't made for that type of current then yea
Username: Jbump
Post Number: 67
I don't think it would matter on the amp, the amp would only draw what it needs, wouldn't it? or could it overload the amp with power, which sounds kinda nuts.. lmao
Username: Lexuscoop
Post Number: 679
well that could be it too, and its giving the subs too much which makes them bottom out and sound like SH!T
Username: Lexuscoop
Post Number: 680
like before with the 8 they were getting a little less and then witht the 4 the amp is actually powering them and they subs can't handle that power
Username: 420pimp2
Post Number: 360
i guess go back to the 8 gauge if it sounds better. thats what i would do leave all technicalities behind when it comes to this situation
Username: Jbump
Post Number: 68
Nah, i'm throwin out the sub tonight and ordering a Type-R so it'll handle the increase in power... Lade gave me 4 extra inches of cable, at $1.30 a foot, and 75 cents for the eyelet connecter, i'll keep my 4 gauge and turn the gain down.. Bump!
Username: Jbump
Post Number: 69
^^^Ladie gave me 4 extra inches.. plus made me cut it >=|
Username: Lexuscoop
Post Number: 682
she mus have been makin up for something else LOL HAHAHAHA JP BRO sorry... had to say it
Username: Jbump
Post Number: 71
No prob.. She was like 70 though O.o
Username: Lexuscoop
Post Number: 702
lol.... the older laidies..... thats the way to do it... the older the more experienced...
Username: 420pimp2
Post Number: 366
the older means less hardness to
Username: Djbass
hi i have a chrysler pacifica and i wanna install a sub system but i couldnt find any place to take the audio wires from if anybody knows please help
