Glasswolf or jonathan, somebody, i have an idea
Username: 54danny54
Betsy layne, Kentucky..GO... USA duh
Post Number: 1751
ok, this is an idea generally aimed towards SPL.
Well, what if u was to get an amp thats puts out say, tiwce ur subs RMS and hook it up to ur subs but on liek a posivtive output of ur amp, put a rehostat(however u spell it). Turn the rheostat down to half way point so ur sub will recive its RMS then whenever u compete u can turn it up full and burp it at twice the watts. Is this possible?
Username: Jonathan_f
GA USA
Post Number: 5585
You already have something that accomplishes this. It's called a volume knob.
All you need to do is determine what level on your head unit would allow the amplifier to provide RMS of the sub on a 0db tone. Make a note of what this level is, and don't exceed it. Then burp away when you want to.
Username: Glasswolf
Wisteria, Lane USA
Post Number: 11060
plus some amps like Alpine's V12 and Zapco's C2K have features that allow you to trim the output peaks to match your speaker ratings, to avoid overdriving them.
