Silver Member Username: GoatinU.S.A Post Number: 216 Registered: Jan-06 | I want to put a second battery in my trunk would I have to run a 0awg wire to the battery in the back and another one back to the (-) in the front?or is there an easier way to do this? | |
Silver Member Username: FandimReno, Nevada United State... Post Number: 698 Registered: Jun-05 | it dosnt HAVE to be 0 gauge...but it's a safe bet. Or you could get a little gasoline powered generator. :-D Short of that..? Nope..gotta send a wire back. (I personally send one for pos, as well as a dedicated ground, as well, that way I dont have to ground to my chasis at all and worry about if the ground is 100% good, as well as what part of the car it's grounded too...cutting out risk of voltage loss due to spot welds, insufficient current carrying capacity of the chasis, etc.) |
Platinum Member Username: GlasswolfWisteria, Lane USA Post Number: 10995 Registered: Dec-03 | the size of the wire depends on the distance it's run and the amount of current drawn through it. if you're using a starter battery and one for the audio system, you'll also need a battery isolator rated for at least the output of your alternator. |
Silver Member Username: GoatinU.S.A Post Number: 270 Registered: Jan-06 | so I can connect the two batteries together one in the front one in the rear with one wire connecting them both can I ground both batteries to the chassis? | |
Silver Member Username: CadillacdbHouston , TX Post Number: 513 Registered: Aug-05 |
Silver Member Username: CadillacdbHouston , TX Post Number: 514 Registered: Aug-05 | Picture at the very bottom of the following link http://www.bcae1.com/battiso.htm Also read the two paragraphs right above the last picture on that page |
