6.5in and 8in subwoofer Tang Band Group Buy
Username: Alteraudiousa
Concord
Post Number: 256
ok, well i couldn't find my thread I had before but there is 4 more days left. I would like to get 4 more drivers sold.
The 6.5 is the:TANG BAND W6-1139SG 6.5" subwoofer, 32$ per driver plus actual shipping
Specifications: Power Handling: 50 watts RMS/100 watts max
*Impedance: 4 ohms
Frequency range: 35-800 Hz
Fs: 35 Hz
SPL: 85 dB 1W/1m
Vas: .51 cu.ft.
Qms: 2.81
Qes: .32
Qts: .29
Xmax 11.5 mm
Dimensions: A: 7", B: 5-1/2", C: 3-5/8"
the 8in is:TANG BAND W8-740C 8in Subwoofer, 44.50$ per driver plus actual shipping
Specifications: Power Handling: 150 watts RMS/300 watts max
VCdia: 2"
Impedance: 4 ohms
Frequency range: 28-1,000 Hz
Fs: 28 Hz
SPL: 84 dB 2.83V/1m
Vas: .81 cu. ft.
Qms: 10.53
Qes: .30
Qts: .30
Xmax: 12mm
Dimensions: A: 8-1/4", B: 7-1/4", C: 4-3/4"
Username: James1115
Ct
Post Number: 5038
hye alter how is the SQ of these drivers?
Concord
Post Number: 259
SQ is good on these. Alot will depend on the install like sound deadening. Also remember these are used for midbass and below so extension isn't too high. I prefer these over the JL 6W0. More output and just as good SQ.
