Powerful 15"?
Username: Usask8er1
Appleton, Wisconsin USA
Post Number: 16
I have a custom box already fitted in my car with a 2500d orion amp. I need a 15" that can pound the shiiit now. Anyone have any up for sale, if not what would all you guys recomend. I have a limited amount of money but I'm open to all suggestions I'm kinda leaning torwards a sub that can handle roughly 2000wats rms. I figure if I have the amp to push it, i mine as well have a sub that can take it. Well let me know what you guys would all recomend. Thanks a bunch. By the way if anyones looking for a comp car with a full system ready to go check mine out. http://www.cardomain.com/ride/2240405
Username: Southern_bass
Paris, Tennessee U.S.
Post Number: 1575
re mt
www.reaudio.com
Username: Pelona
Post Number: 536
15" orion h2
15" eclipse ti pro
15" re mt
Username: Jakeyplaysbass
St. Louis, MO
Post Number: 548
Treo SSX
St. Louis, MO
Post Number: 549
was that 166.7 db in the port or dash and what mic is it on? thats very very very very loud.
Username: Pelona
Post Number: 538
very loud
St. Louis, MO
Post Number: 550
another question why does ur profile say you have 2 Audiobahn 15"s and the link has 4 15" IDmaxs? im guess the car is a friends or something?
Username: Pelona
Post Number: 539
thats probaly just his competition car.
he probably just uses the audiobahns for daily use in his car. lol
Username: Usask8er1
Post Number: 17
I havent update my profile in a year but yes pelon ur right it was for my daily driver. The comp car i actually inherited from my brother when he went to college. I believe the mic was used at the dash but I'm not sure. He knows a lot more about this than i do. As for my daily driver i had a 15" power acoustik but it blew in two weeks even with my amp down to like 25%
Username: Pelona
Post Number: 541
you went from audiobahn to power acoustik? bad choice.
Username: Tdeaton1021
Near Tampa, Florida USA
Post Number: 1801
dont they only make idmax's from 10-12inch?
the NEW RE SX....
team rockford fosgate....
Username: Usask8er1
Post Number: 18
those subs are not idmax lol there called idspl there impossible to get and worth a crap load. My bro only got them because he competed for Image Dynamics a couple years back. He said something along the lines of only a hundred or so were made but there insanly loud. By the way has anyone used or heard a rfl sub and what did you think?
OOOOOOOOOOk
just buy a sub that can take the power and is matched with cubic feet of volume in the box. Ive a million different subs in the same power from cheap to expensive and they all sound the same if there in the same power class.
Username: Usask8er1
Post Number: 19
well the box is roughly 3.5 cubes but I plan on having the sub mounted inside out, Dont know if it makes a difference or not
