Home Sub-amplifier with Car subwoofer?
Username: Rzarector
Coquitlam, Bc Canada
Post Number: 907
i know its been asked alot about running car subs in your house... but i have a 8" sub in the basement i think its around 200 watts rms probably at 8 ohms.. if i hooked up a w3v2 to this amp would it be fine? does the power differ from home amplifier and car amplifier?
Username: Scubasteve
College Park, MD
Post Number: 916
whats the impedence of your w3v2? You should check the impedence the amp is seeing now and test it out with the w3v2 and see how it goes.
Bob365
If you got the dual 4 ohm version, you could wire the voice coils in series to run at 8 ohms.
Username: Rzarector
Post Number: 915
jl is a dual 4 ohm so it can be hooked up to 8.. how do u test impendance on coils with multimeter?
Bob365
Username: Killerzracing71
Fredericksbutg, Virginia United states
Post Number: 303
switch the mulitmeter to the ohms setting and mesure the impedence off the sub woofer
Username: Rzarector
Post Number: 929
k built a box yesterday and hooked it all up was working good.. got some friggin port noise though il have to flange them and hopefully that will fix it.. i was playing it pretty loud and then in stopped.. pulled the home amplifier out and i the fuse blew on it.. this would have nothing to do with the sub would it? i mean both subs will give it an 8 ohm load.. i figure the settings were just to jacked up and i played it to loud?
