Kicker Comps
Username: Bies08
Wheaton, Kansas
Post Number: 43
A friend is tryign to sell 2 12 Kicker Comps. They arn't he silver ones. He's used them for about 6 months. The only problem is, whats the difference between the silver ones, and the black ones? Are the black ones just junk or what? He only wants 100 for both subs. I was gonna sell mine with the box for 150. I figured the kickers would hit harder than what mine do. If you want to know what i have look on my whatever.
Username: Chaunb3400
Huntsville, Alabama U.S.
Post Number: 5244
the black 1's are the comp's (250rms) the silver 1's are the compvr's(500rms), The vr's are nice the comps not so much
Username: Bies08
Wheaton, Kansas
Post Number: 44
Is it worth buying them for both 100?
Post Number: 5245
do they come with the box
Username: Bies08
Wheaton, Kansas
Post Number: 45
No, but i already have a box
Post Number: 5246
U can get some brand spankin new 4 $120
http://cgi.ebay.com/2-Kicker-COMP-C12-12-600W-Pair-Subwoofers-NEW-2005-HOT_W0QQi temZ5863235386QQcategoryZ39777QQrdZ1QQcmdZViewItem
Personally i would not waste my time on comps, maybe cvr's
Username: Bies08
Wheaton, Kansas
Post Number: 46
I want to upgrade my subs soon, and i want to get kickers, but i dont know which ones to get. my friend has the CVR's...and they hit..but hes also got a 900 watt mono block Kicker amp, so that would change alot
Post Number: 5247
what kind of amp is that never heard of a 900 watt mono kicker amp??U sure its not the 900.2??
Anywho whats ur budget
Username: Bies08
Wheaton, Kansas
Post Number: 47
nah...he told me its a 900 watt mono block....idk...i dont think i'd wanna spend over 300 on both..i like the L7's..but everyone says taht they suck for sound quality
Post Number: 5248
What kind of music do u listen 2, it may sound kinda silly but it would help pick the kind of sub for u.
Type R's
Pro X212
RE SE
Ed.v2
V-Max's, etc
Username: N2audio
Lawrence, Ks USA
Post Number: 559
Isn't it Comp = 150w, CVR = 300w?
Tell him you can get 2 new ones from etronics for $120-$125. Maybe $75 would be worth it.
you live in the wonderful metropolis of Wheaton huh?? A thriving population of 116! LOL
I've got grandparents/anut/uncle that live in Havensville. A brother up north in Seneca.
Post Number: 5249
a cvr 10" is 300 rms, 12" 400 rms and a comp 10 and 12 are 150 rms
Also i would look into these
http://www.partsexpress.com/pe/showdetl.cfm?&DID=7&Partnumber=295-404
Username: 2icey
ANAHEIM, CA
Post Number: 37
chauncey are the compvr's best for rap?
Post Number: 5251
The L7's are best for rap, Solo X's for competitions, and L5's for paper weight.
Username: Import
Maple shade, Nj Usa
is it worth trading a 12" l5 in the kicker box for 2 12" kicker comp crv's wit a box or should i just upgrade my l5 to a l7
Username: 54danny54
Betsy layne, Kentucky..GO... USA duh
Post Number: 1744
lol @ L5's for paper wieght
Username: 54danny54
Post Number: 1745
upgrade to L7
Username: Import
Maple shade, Nj Usa
wat do u mean by paper weight
Username: Import
Maple shade, Nj Usa
wat do u mean by paper weight?
Username: Goatin
U.S.A
Post Number: 263
it means you should buy my brand new 15" L5!!
Post Number: 5320
worthless,pointless, not worth buying
Username: Goatin
U.S.A
Post Number: 264
C'mon Chauncey your killin me.lol
Username: Import
Maple shade, Nj Usa
i already have a l5 so wat should i do now
Username: Goatin
U.S.A
Post Number: 265
buy mine so you will have 2.
Username: Import
Maple shade, Nj Usa
Post Number: 7
should i just buy a l7 so i won't have to waste so much space in mah trunk. and i heard its as loud as 2 l5's
Username: Goatin
U.S.A
Post Number: 266
2 L5s will be louder than 1 L7.
Username: Goatin
U.S.A
Post Number: 267
you only need 6 cubic feet to run 2 of the 15" L5s
Username: Import
Maple shade, Nj Usa
Post Number: 9
yea but then i will need a new box or another one
which means more money
Username: Bies08
Wheaton, Kansas
Post Number: 48
Yeah, i live in the wonderful area of Wheaton, technically i live over inbetween onaga and Wamego in the boonies...but ya....idk...most of the stuff i listne to is like Bone thugs-N-Harmony. I already have a Alpine MRD-M605...i was thinkin taht if i got 2 L7's then i'd just buy another amp identical....but idk...
Post Number: 5341
u will be slightly underpowering them, whats ur budget on amps, if u get the 2 L7's???
Username: Bies08
Wheaton, Kansas
Post Number: 49
basically any thing..like i wanna get a really good system...ima gonan be saving up for awhile...but i dont wanna spend over like 500 on just the amp...
Username: Night_mirage
AmmanJordan
Post Number: 99
L5 as Chauncey Brown said its for paper weight
cvr is better .
and its 400 w RMS not 500 w
800 peak
thanks
