Can anyone recommend an amp????
Username: Shaun_whitaker
ok here is the setup i plan on buying. i can also get a dual 2 ohm version.
http://cgi.ebay.com/Kicker-S12L5-L5-SOLOBARIC-Subs-Woofer-Speaker-SUB-BOX_W0QQit emZ5865601730QQcategoryZ39777QQrdZ1QQcmdZViewItem
can anyone recommend a good amp for this sub. i can get it in either dual 2 or dual 4 ohm. please help thank you.
Username: Blainew
Post Number: 933
if u get one get a dual 2 ohm
if u get two get dual 4 ohms
get a one ohm stable amp
i would like to get and amp that puts out about 600 x 1 @ 4 ohms. i was asking about a recommendation on a certain amp. so can someone recommend a good amp please. thank you
Username: Tjmutlow
Post Number: 1451
jl, 500/1, or the pheonix gold xeon series 600.1 or you will nedd like a 1000-1200w normal rated mono amp.
Username: Dustin3
Tigard, Or U.S.
Post Number: 430
get the audiobahn a8000t or a8002t...
