New member Username: Peabody67gtoPost Number: 3 Registered: Feb-06 | Hi, I have an original 67 GTO with the factory AM indash radio and a factory 8-track underdash with front and rear 6x9 speakers that are 10 OHMS. I need to replace them because that are almost 40 years old. I cannot find any 10 ohm speakers so I wanted to know if I use a lower ohm speaker will it harm my radio and tape deck? THANKS |
Platinum Member Username: GlasswolfWisteria, Lane USA Post Number: 11071 Registered: Dec-03 | you can use a 4 ohm speaker or an 8 ohm speaker if you use something called an L-pad to attenuate the load. here; http://www.bcae1.com/lpad.htm PS good luck with the Goat. I drive a 66 charger myself.. although I didn't go the resto route. I made her into a streeter. 500" ICH motor, custom audio setup, whole new drivetrain and suspension etc. fun cars. |
