Required fuse
Username: Astrosafari
Delhi, Ontario Canada
Post Number: 259
i have a 600 watt rms (150x4) amp bridged to a 500 watt rms sub. i dont know what kinda of fuse i should use on my power wire, without going out and buying a big amp kit, where i wont use all of it because i have most of what i need. can any one tell me what kind of fuse i need? like size type?
Username: Mph
Post Number: 23
Just do a search for am amp kit for that amp and it will tell you what fuse size they normally use. As a guess I would figure it would be in the 30 to 60 amp range.
look at how big the fuse is on your amp. and match your power wire fuse with the same size as your amp. i'm assuming its probably 60amp.
