markho311 Unregistered guest | I'm looking into buying an RE Audio 12" SE, its dual 4 ohm and runs at 600 watts RMS, I was having trouble finding an amp to use with it at a good price and wondered if anyone could help with some suggestions. |
Silver Member Username: BlainewPost Number: 878 Registered: Nov-05 | save some money...get two of those and and RE12.1 you wont be dissapointed |
markho311 Unregistered guest | i'm on a bit of a budget squeeze right now so i'll only have enough for the one sub and an amp at the moment |
Silver Member Username: BlainewPost Number: 880 Registered: Nov-05 | well your going to need to get one that does 600 RMS at 2 ohms i think the last year kickers were stable at 2 ohms, other than that look at orion, or hifonics |
Silver Member Username: N2audioLawrence, Ks USA Post Number: 549 Registered: Mar-04 | This is certainly worth considering. http://ikesound.com/product-product_id/3852 |
markho311 Unregistered guest | you think a profile AP 1200 would work? |
Silver Member Username: N2audioLawrence, Ks USA Post Number: 551 Registered: Mar-04 | A lot of people on this forum like to discard Profile as junk, but I think they're full of themselves. Very good budget amps IMO. However, with your one 600w DVC4 there is a better option than the ap1200. With a 2 ch amp the best you could do would be to wire the coils in series for an 8 ohm load bridged. That would result in about 400w from the ap1200. With the AP1000M you could wire your coils parallel for 2 ohms and get 500w for a few $ less than the 1200 (at least at millionbuy.com). Not a big difference, but more power for the same or less money is always a plus. |
