Brahma
Username: Suicideshifter
Bristolville, Ohio United States
Post Number: 99
how would a brahma 10" work in a .79 cuft sealed encloser? how many watts u think it would need? and how u think it would perform?
Post Number: 100
no responses?
Username: Mike_anthes
Canton, SD USA
Post Number: 329
generally with a smaller sealed box you need a little more power to get it to its full potential...im not sure what the smallest recomended box is for the brahma 10"...sry...
Username: James1115
Ct
Post Number: 4918
dual 2ohm or dual 4 ohm? mkII or MKIII?
Username: Mikechec9
Http://www.cardomain.c...
Post Number: 2111
information is essentially the same as listed in the lower portion of this link
http://www.easy-audio.com/products/caudio/drivers/brahma.htm
Username: Mikechec9
Post Number: 2112
