Help....QUICK
Username: Bp317
Post Number: 44
alright i have an mtx 8500 12 hooked up to a PA 1600 watt amp (puts around 600) wired at 2 ohms. When i turned my car on there was just a constant thumping coming from the subs, even when the music was down at zero. what am i doin wrong? thanks!
Username: Young_james
Post Number: 766
check all wiring and make sure nothing is shorting out. Double check the ground too
Username: Rovin
Trinidad & T...
Post Number: 5409
quite possibly a bad ground connection or other settings
check ground connections & set everything on neutral & see what happens.......
Username: Rovin
Trinidad & T...
Post Number: 5410
aaaaaah - u beat me 2 it by a few seconds ..lol..
Username: Bp317
Post Number: 45
alright, i checked the ground and it was pretty weak so i changed it and that has helped. Now, it doesnt make the continious knocking, but they dont seem to hit that hard...is it because they havent been broken in yet? and also when i changed songs there is a thump in in the subs.
Username: Bp317
Post Number: 46
i wired to one positive and in that same terminal there is another wire that goes to the next positive, same with negetive. thats would make it 2 ohms right? haha
