Can i wire this
Username: Texas_bass
Houston, TX
Post Number: 235
its 3 speakers with dvc 4ohm when wired it would be 2.66 ohms can i wire them to a hifonics amp
Bx1605d
@2 ohms 1x1000 rms
@1 ohm 1x1600 rms
if not please let me know what i can use
Username: Teddy21
Ann Arbor, MI USA
should be fine, you will be getting just less than the 1000 watts
Houston, TX
Post Number: 236
Thanks for the info
does anyone agree or disagree
Username: Islandboy808
Mililani, Hawaii US
Post Number: 620
whats the rms on the speakers
Houston, TX
Post Number: 237
400 rms
Username: James1115
Wilton, Ct
Post Number: 4869
that is the root mean squared power(average) power the subs can handle. With those subs and that amp each sub will see around 300 rms. that should work fine for you.
Houston, TX
Post Number: 238
its 400 rms for each speaker
Username: James1115
Wilton, Ct
Post Number: 4870
if thats what they say then yes. if you wire the 3 subs to 2.66 ohms each sub will see about 300 watts, which will be fine for subs with a rms of 400.
Houston, TX
Post Number: 239
kool thanks for the help
