HELP PLEASE!!
Username: Utengineer13
Ok so my aplifier is on, but my subs arents hitting, I rechecked all wiring, what could be the problem?
Username: Solacedagony
New Jersey US
Post Number: 798
Check to make sure your RCAs are good. Is it going into protection mode? If so, your gain setting or load from subs may be incorrect.
Username: Tjmutlow
Post Number: 1375
maybe out of phase, setting on amplifier, or just not enough power, or oham load is high and not getting full power from amp., radio settings, could be anything...
I really dont know anything about this stuff, but my subs are hitting a little bit, but they arent getting full power, or at least thats wat it seems like to me. Any ideas? Thanks from a newbie.
Username: James1115
Ct
Post Number: 4890
it could be many things, we need to know a little more info. what subs do you have? what are the voice coil impedence(ohms)? how do you have them wired series/parellell? parellell/parellell? what amp? what is it rated at(watts) what impedence (ohms)? that is enough to get us started.
