Bronze Member Username: Jprix82Post Number: 98 Registered: Jan-06 | What does BL on a sub mean? |
Gold Member Username: Mikechec9Http://www.cardomain.c... Post Number: 2105 Registered: May-05 | motor strength |
Bronze Member Username: Jprix82Post Number: 99 Registered: Jan-06 | What does that have to with the subs performence? |
Gold Member Username: Mikechec9Http://www.cardomain.c... Post Number: 2106 Registered: May-05 | BL=mass/current. a BL >30 typically means tight, controlled/accurate cone movement and low Qts (which has nothing to do with cone size, by the way). that is, a high BL HELPS to result in good transient response. but you can also have too great a BL known as an "overmotored" sub. a driver with a Bl of <20 will generally be boomier and not as controlled. one spec means very little without the others taken into consideration, however. http://editweb.iglou.com/eminence/eminence/pages/params02/params.htm |
Gold Member Username: Mikechec9Http://www.cardomain.c... Post Number: 2107 Registered: May-05 | . |
Bronze Member Username: Jprix82Post Number: 100 Registered: Jan-06 | so the higher the BL the better? |
Gold Member Username: 54danny54Betsy layne, Kentucky..GO... USA duh Post Number: 1687 Registered: Nov-04 | not really...but it helps |
Platinum Member Username: GlasswolfWisteria, Lane USA Post Number: 10987 Registered: Dec-03 | for a SQ sub yes, you want a high BL with a nice parabolic curve. For an SPL sub, BL isn't as important since a high BL indicates an overdamped sub, and that decreases efficiency, so it decreases output and sensitivity. |
Silver Member Username: Jprix82Post Number: 103 Registered: Jan-06 | ^^^^^Thats what i was looking for^^^^^ thanks GlassWolf |
