How do u hook up Overhead Monitor
Username: I8eb4
Post Number: 19
how do u attach a Overhead Monitor to your roof
Username: Islandboy808
Mililani, Hawaii US
Post Number: 609
u have to drop down the headliner
Username: Tjmutlow
Post Number: 1347
no you don't on almost all vehicles, what type of car is it?
bryan stonebrokler
a 97 F-150 single cab
forgot my password
Mililani, Hawaii US
Post Number: 613
well for mine u had to just a little.i didnt mean drop the headliner all the way down,just a little so u can run the wires.why ty is there an easier way.
Username: Tjmutlow
Post Number: 1355
does it have the huimps near center, if not drop overhaed light if it is near center, use 1/8 or 1/4 wood strips between headliner and roof, then fish a coat hanger from either side of truck to opening (light). mount the bracket to roof, connect the wires(and tape connectionsa) then mount the tv to the bracket.
