Can i wire a DVC sub to a 2 channel amp?
i was wondering if you have a DVC sub and a 2 channel amp can you wire the 2 channels up to each coil. like one channel to one coil and the other channel to the other coil. because the sub i have is rated at 300 watts per coil. and the amp i have puts out 250 x 2 @ 4 ohms and each coil is 4 ohms. can someone please help. thank you
WiseBro
you will get more responses if your registered !
