Box material
INAFIA
rather than 3/4 inch MDF would 1 inch MDF sound better?
Username: Alteraudiousa
Concord
Post Number: 141
yes it would be better but also have draw backs like weight. I would use 1in MDF on long planes like the back of the box, top of it or front side where the subs srew into. I usually do on mine 1.5in thick front and back with skeleton bracing on the inside.
Username: James1115
Ct
Post Number: 4942
it also depends greatly on the sub you plan on running. A cheap audiobahn sub will not show much bennefit in a 1in mdf over 3/4in braced properly, but if you step up to a "Super Sub" set-up then other measures will need to be taken exactly as alteraudio said.
Username: Scott_debaker
Pittsburgh, P.A. U.S.A.
Post Number: 58
think i can use 2 or 3 2/4s for bracing in my 5.25cf box
Username: Spyder
Eglin AFB, Florida USA
Post Number: 287
i use 1.5inch mdf for my 12 w7.... usually the thicker it is to a point the more sturdy the box is.
