Temp system till im back on track
Username: Texas_bass
Houston, TX
Post Number: 218
i was thinking of going with one of these for a temp setup for my truck let me know what you think
http://shop1.outpost.com/product/4525517?site=sr:SEARCH:MAIN_RSLT_PG
http://shop1.outpost.com/product/4391315?site=sr:SEARCH:MAIN_RSLT_PG
Username: Mikejr41888
Post Number: 8
i had the visonik package, dont get it the amp is only 400 watts max, n the subs suck
Username: Celica150db
Australia
Post Number: 46
I dont know what other people will or would say but i'd go with
Visonik VB212PKG
Dual 12 inch Bass Box Car Subwoofer
With 1000W Amplifier Party Pack
just coz it looks better then the Fusion
plus the VISONIK has more info!
thats my guess
good luck
Houston, TX
Post Number: 219
here is the data on the fuison
Technical Data
12" Encounter Loaded Enclosure
Woofer Features
Magnet Structure 80 Oz
Power Handling 400 Watts
Frequency Response 23Hz to 3kHz
Impedance 4 Ohms
Efficiency 91dB
Voice Coil 2 Kapton SVC
Enclosure Features
18mm MDF Board
Black Carpet
Heavy Duty Gold Plated Terminals
Acoustically Lined Inside Ported
Tuned Wedged Back
2 Channel Encounter Amplifier
Complies with CEA 2006 Amplifier Power Standard
65 Watts RMS per channel @ 4 Ohms and d1%THD+N
2 Ohm Stable Operation
Gold Plated Audio Connections
FUTRANZ Efficient Heat Sink Design Technology
F.I.S.T. FUSION Intercooled Semi-conductor Technology
F.R.A.T FUSION Regulated Amplifier Technology
Direct in 4 Gauge Gold Plated Power Connector
Military Spec Componentry as Standard Issue
Damping Factor > 200 T.H.D. 0.05%
Variable HP & LP Electronic Crossover @ 18dB/Octave
Frequency Response 5Hz - 38kHz
Dimensions (mm) (W) 220 (L) 210 (H) 57.5
4 Gauge Amplifier Installation Kit
1 x 5m 4 Gauge Power Cable (16.4ft)
1 x 1m 4 Gauge Earth Cable (3.2ft)
1 x 5m 18 Gauge Remote Cable (16.4ft)
1 x 5m Performance Series RCA Interconnect (16.4ft)
1 x AUE Fuse Holder and Fuse, 60 Amp
All Installation Hardware Included
12 Gauge OFC Speaker Cable
Length: 16.4 ft / 5 meters
Username: Buckshot
Post Number: 17
my temp system is ok i got 2 12" RF p1 with a p200 amp it works decent for now
Houston, TX
Post Number: 220
I though about picking up a box with just the subs in it and going with my own amp but havent seen anything that i rally like or was halph way desent and suggestions
Username: 54danny54
Betsy layne, Kentucky..GO... USA duh
Post Number: 1657
fusion man...i love fusion car audio(yes i personnaly heard there lower model and thier power planty)
Houston, TX
Post Number: 221
do you know if thay have any thing else out
Username: Pelona
Post Number: 323
i just got this temporary system until i get enough money for two 15" TIS with an Orion 2500d. Im pretty sure its better than that fusion and visonic crap.http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem%26item%3D5855586066%26&sspagename= STRK%3AMEWA%3AIT%26
Username: Cenus
Hicksville, Ohio Usa
Post Number: 1168
nice zr amp, the amp alone is worth that much.
Username: Pelona
Post Number: 325
really? alot of people said that they dont know much about that amp.
pelon is full of sh!t,u cant afford that system, stop trying to be cool lol.btw u dont know sh!t about car audio so stop posting and learn.
Username: Cenus
Post Number: 1170
ohh ya, kicker zr amps are very nice, they have very, very low thd rates,and overrated, they make great componet amps.
Username: Pelona
Post Number: 326
i cant afford $102.50? and how am i trying to be cool? i know that kicker system isnt the best.
btw most of my posts are questions. so i AM learning. and i bet i know more about car audio than you. and i only give advice on something ive heard and seen.
Houston, TX
Post Number: 222
I was checking out the ones below give me and opinion
http://www.sonicelectronix.com/item_3469.html
http://www.sonicelectronix.com/item_3065.html
http://www.sonicelectronix.com/item_4330.html
http://www.sonicelectronix.com/item_5705.html
Username: Pelona
Post Number: 333
why dont you just get a low price quality brand? all the brands you put up are pretty cheap.
Houston, TX
Post Number: 224
because i want something that will sound ok because when my boss ticks me off it gets loud in my truck which is about every day so i want it loud
Username: Pelona
Post Number: 336
you mean everytime your boss pisses you off you just turn the volume up in your truck to relieve the anger?
Houston, TX
Post Number: 226
yea then i cant hear the phones or have to listen to him since i work out of my truck and do alot of driving everyday it kinda works out for me
that or i tell him off and we yell at eachother for about 5-10 min till we cool off
Username: Pelona
Post Number: 337
you should get this one thomas. its better than all the ones you mentioned.http://cgi.ebay.com/MA-AUDIO-HK400D-MA212B-AMPLIFIER-SUBWOOFER-BOX_W0QQitemZ5860 982850QQcategoryZ32822QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
Houston, TX
Post Number: 228
i was looking at that one too
Username: Cenus
Post Number: 1173
what about this setup, a kicker kx200.2 ($120) and a ascendant audio assassin 10 or 12 ($85-$95) that would be a little over $200 and would have great sq and get fairly loud.
Username: Spyder
Eglin AFB, Florida USA
Post Number: 283
what is your budget.....and possibly we can assist you in finding other great deals....
Houston, TX
Post Number: 232
about 300-400 for now
was wanting 1 or 2 subs and amp
Houston, TX
Post Number: 233
what do you all think about volfenhag
