3 JL AUDIO 12" w6 WHAT amp DO I need???
Username: Nyrider
Rochester, NY
First off let me thank you proffesionals for the information you guys give. Sometime's I just sit here and read all the threads I can.
Now to my problem I have 3 - 12" jl audio w6
and was wondering what amp would really push all 3 subs hard I mean crack your rearview window hard. And whatever amp you guys recommend how should I wire them to match in series or parrallel
Thank you again
Username: James1115
Wilton, Ct
Post Number: 4814
are the w6v1's or w6v2's?
Username: Nyrider
Rochester, NY
they are dual voice coil
Username: James1115
Wilton, Ct
Post Number: 4815
yes I know they are dual voice coil but ARe they 12w6's or 12w6v2's? are they dual 4ohm voice coil or dual 6ohm voice coil?
Username: Nyrider
Rochester, NY
well there old speakers they only are stamped 12w6 on the magnet but have a upc # of
04 b w l 3 8 0 97 Sorry I hope this help the subwoofers were given to me
Username: Nyrider
Rochester, NY
I do have an ohm meter is there anyway for me to test the speaker
Username: James1115
Wilton, Ct
Post Number: 4819
do they say dual 6ohm on the magnet? do they have an inverted dustcap ot do they have a dust cap that says JL on it? I am pretty sure they are the v1's, if they are then I have the same subs. I ran mine off of a ppi a600 and they saounded fantastic:-)! they would sound good off of a 500/1 also.
Jered
But like the man asked, how do you wire them?
Username: James1115
Wilton, Ct
Post Number: 4823
well that all depends on what amp you run them off of!
Username: Tjmutlow
Post Number: 1329
Looks like the 04 model, go to www.the12volt.com and go to woofer wiring, i think those are dual 6 and if so they can wire down to 1 ohm, just check the website.
