Breaking in a speaker
Username: Graphix1
Santa Rosa Heights, Arima Trinidad & T...
Post Number: 610
what is it?
what will happen if you dont do it?
Username: Graphix1
Post Number: 611
Bump.....damn this forum is dead these days...
Username: Touche6784
Post Number: 881
you simply play the speaker. some people say that there is no such thing as break in. usually the surround needs a little time to move around kind of like a car engine needs the pistons to move around to be broken in.
Username: Graphix1
Post Number: 614
ok
what will happen if you dont break in a speaker
Post Number: 889
you use the speaker you are breaking it in. you dont use the speaker you dont break it in. still confused?
Username: Insearchofbass
Post Number: 4521
if you blast the sub before its brooken in you stand a higher chance of blowing the subwoofer or causing minor damage
Username: Graphix1
Post Number: 615
well i meant that if you dont break it in(play it at low volumes for a good enough period of time)
and blast it loud....what would happen...
arite sean i guess that answers my ques.
Username: B101
Queen City, NC USA
Post Number: 855
Nester just start playing the sub at its rated RMS.
Thats "breaking it in"; After a few months the spiders and the cone will soften up even more!! Making it sound even better!! =D
Some subs may have alot of spiders, making it a stiffer sub.
I SLAMMED my subs when I hooked them up, and the sound better 2day =D
But I would start them off with the rated power first. lol
