Something is wrong with my pioneer cd player in my Jeep help
Username: Bret
Okc, Oklahoma Usa
Post Number: 32
Every time I change channels or put in a cd, it pops twice sounds like im going to blow my subs and my door speakers has anyone expirence this crap
is it a bad connection or bad stero i dont no what to do
any ideas talk to me
Username: Southern_bass
Paris, Tennessee U.S.
Post Number: 1057
did you hook it up or was it professionaly installed
Username: Bret
Okc, Oklahoma Usa
Post Number: 33
i hooked it up
Username: Bret
Okc, Oklahoma Usa
Post Number: 35
anyone have an idea hello big proble
lol
Username: Bret
Okc, Oklahoma Usa
Post Number: 36
anybody
Los Angeles, CA USA
Post Number: 2118
does it do that at lower volume too? a friend of mine's car did that and we couldn't fix it. so everytime he just lowers the volume and the sound isn't as loud. sorry i couldn't help you fix the problem.
Username: Bret
Okc, Oklahoma Usa
Post Number: 37
yep i can lower the vol to 1 and its the same as like 30
dos yours do that
Los Angeles, CA USA
Post Number: 2122
oh then its different. cause my friends when he lowers the volume it also lowers the volume of that annoying sound.
Username: Jemone
Stone Mountain, Georgia United States
Post Number: 45
hey maybe you sould try an in line filter.your volume may be alittle lower but it may eliminate that sound
Username: Bret
Okc, Oklahoma Usa
Post Number: 44
how do you put it on
Username: Bret
Okc, Oklahoma Usa
Post Number: 46
Username: Lewass
Bloomfield Hills, MI USA
Post Number: 8
I just installed a new sub to my same amp and my Pioneer HU (an older DEH P4600) and it makes that pop when I first turn on the car, but I don't think it is as loud at 1 as it is when the volume is up... But the HU didn't make that sound before with my old subs. I am using way thicker speaker wire and it's now wired at 1 ohm, so it could be either of those things causing it...
Username: Bret
Okc, Oklahoma Usa
Post Number: 47
when i turn my cd player on it dose it to
i think i need a another one
